hello, i need a ROM backup (ROM Image) for Acer n35 because i tried to make an update (n30) and the pocket pc software crashed. can anyone help me please
I have the same problem as uli160.
I have tried downloading the file from the acer link, but it keeps failing. Is there somewhere else I can download it from, or could someone FTP it to me?
Many thanks
Peter
I need an osimage for Acer N35 in french version. I did not find it on the site of ACER.
My Acer was in french first, but i overwrite it with an english one, in order to do an upgrade and fixing some bugs. please help me
I have got the latest ROM files from the Acer site but don't know how to do the update itself. Acer don't seem to want to reply and I cannot find any instructions other than hold the power key and do a reset then I get "Download Img" one a wight screen and it never does anything else.
Anyone got any more info on what should happen and how long it takes and where to put the update files?
first go to ftp://ftp.acer-ee.com [if you're from Europe] or ftp://ftp.acer.com from USA.
then use an SD card , optimal 64+ mbs
!!! FORMAT THE CARD VIA PC AS FAT !!! NOT FAT32 [which is default] !!!!!
Then follow the simple instructions
1. copy all OS Image files to SD card [now formated as FAT system]
2. hard restart Acer n35 device [move knob to the left]
3. Instert the SD Card
4. Hold the power button, and move the hard reset knob to the left
5. aproximatly count 4 sec. and release the power button
6. the screen will say SD DOWNLOAD [not DOWNLOAD IMG] and then after ~10 sec. the Orange bar will appear
7. The device will reboot automatically after it has completed flashing .
THAT's it... the FAT32/FAT thing.... god damn , 6hrs lost on that ****...
Hope you won't loose so much .. :)
One more thing , to upgrade to the files in n35_sdv1.40.32_wwe.zip
just use the procedure above
if you want to upgrade to files in n35_SE_v2.10.12_WWE_SD.rar
first load onto your SD card the files from n35_SE_Eboot 6.2.rar
then reboot device
and load onto SD card the files from n35_SE_v2.10.12_WWE_SD.rar
and repeat the flashing procedure.
The last part _WWe , FRA , ESP , GER denotes that the software in files is in that language and WWe is World Wide...
Bye guys ..just converted my acer n35 **** from Spanish to plane good old English
Werner Ruotsalainen
Moderator
Please read your mail. It's pretty important.
ulti160
thanx i will delete PIM info ....
dkotas
can someone please repost a link to n35 rom in english, would be greatly appreciated. Thanks much
realworld
can we update n30 by n35's rom??? here is the rom of n35:
http://csd.acer.com.tw/SI/Download2.nsf/HandHeldWeb?OpenView&Start=1&Count=240&Expand=3#3
legind
Many thanks
Peter
zbigboss
Hi folks,
I found a the following link ftp://ftp.support.acer-euro.com/handheld/n35/osimage/ [^]
I did not flash my device at this moment, so I can't tell you if it works.
If someone had flashed his N35 can you please inform me how it went?
Thank you.
[8D]
Cheers,
Cees
Cheers,
Cees
khoury
Hello,
Thanks
sonicm
Hi,
Thanks
Mike
khoury
Hello,
I need an osimage for ACER N35 french Version.
For English version go to the following site
thanks
sroor9001
any bodys know the instruction of updating rom?
markojan
hahahahahahaha
it took me 8 hours but i finaly figured it OUT
then reboot device
baseman
Hi...
Anyone in need of n35 os images, check this forum:http://www.expansys.com/ft.aspx?k=101003&page=1
Regards, baseman.
