I was trying to update my WLAN firmware (found here:http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/locate/105_5643.html ). I got to the part where the screen prompted me for confirmation to install. I then decided maybe it was better to update after I'd clear everything (I was going to start from scratch, dumping my junk). So instead of confirming, I did a factory reset.
Now, I thought I didn't start the firmware update yet, but I may be wrong. Because now, even after factory resetting, the device hangs at the hp logo splash screen.
Any ideas? (Did I just mess up my hardware? Is there hope for recovery?)
-jnghh
