It's, fortunately, pretty easy if you don't have WinXP SP2. (If you have SP2, building up to the Personal Area Network (PAN) must be done in a way explained in the next forum post.)
1. pair your PDA with your desktop
2. in your PDA's Bluetooth Manager, choose New/Connect!/Join a personal network. On the next screen ("Please select whether you would like to join or host a personal network") leave the default 'Join' set; just press Next (WM2003SE users, note that this screen doesn't exist under your op. system!). After this, just choose your desktop PC from the list of the already paired devices.
Here, just press Finish and, consequently, click the bulb that comes up on the desktop PC. In the dialog box that then comes up, check in the "Always allow" checkbox and click OK.
Please note that the desktop name is "BlueTooth" in the picture above - you'll most probably see a different name, depending on whether you've given a non-default name to your desktop computer.
3, still in BT Manager, in the My Shortcuts tab, tap-and-hold the newly created icon and choose Connect. The icon becomes green:
5, choose the icon next to the Tools menu and enter any name (it'll be the local name of your share inside the \NETWORK virtual directory) in the upper (Local name) box and the name of your desktop PC and the share name in the Remote path field.
For example, if your desktop computer's name is WR2 (this comes to my name's initials and and index to denote that it's my 2nd desktop PC) and the shared directory in the form of
\\<desktop computer's name>\<directory name>
If you are unsure about your computer name, go to Start Menu/Settings/System/Name (I'm not sure about this - I have Finnish Windows and just tried to guess what was the original English name)
Now, on the following screen,
if you have a non-restricted share on your PC, just click OK.
6, in the list on the third image above, the new mapping appears:
Just click it, and you'll be redirected to the contents of this directory at once, inside File Explorer:
Please note that you can always return here by clicking the second 'memory card' icon in the below (it's highlighted in the image!) or clicking the up arrow next to Open.
Now, you can get your favourite MP3 player. I recommend BetaPlayer (http://betaplayer.corecodec.org ) for this because it has decent network handling and very easy streaming over network shares, unlike Windows Media Player. Go to File/Open File, and enter \NETWORK\<your local share name> in the directory (please note that it's already a local name; hence the single leading backslash, as opposed to accessing shared directories). All the media files will be visible; you can play any of them and/or easily put in a playlist (for this, just click All in the bottom right and then Ok).
Please note that, as I've pointed out above, the mapped drive won't be visible in the root file system shown by File Explorer. To remedy this situation, you may get a registry editor and go to HKEY_LOCAL_MACHINE\Comm\REDIR :
Here, click RegisterFSBoot and change the value 0 to 1:
Save the new value (in Resco Registry Explorer, press Ok and Yes). After a reset, a new Network (virtual) subdirectory will appear in File Explorer:
Please note that if you need more info on using the built-in Windows Media Player to access network shares and I'll explain how it can be done if you want to access more than one file at a time.
If you want to set up a PAN with the built-in Microsoft driver of Windows XP SP2, you need to do the following:
1, In the above step 2, instead of leaving the default 'Join' on, choose the second, 'Host' radio button. ('Join' won't work - the PDA will just display the absence of the necessary BT profile on the server.)
2, on the next screen, click Add and choose the already-paired (please note that you need to initiate the pairing process from Windows) Windows desktop icon.
3, upon the first time of the connection, a bubble will appear on both the PPC and the desktop computer, where you will need to enter a common PIN key. Use, for example, 1. Upon consequent connections, if you opted for not using any kind of compression upon pairing the devices, no PINs will be requested.
Please note that, unlike with the Widcomm BT stacks, no PAN icon will be created in the My Shortcuts tab. This is one of the many reasons of switching to using the Widcomm or BlueSoil BT stacks under Win XP SP2 too.
WM2003SE users, please note that the above steps need not be done: in WM2003SE BT stacks, a new, Personal Network Manager menu point has been added to the Tools menu. It does exactly the same as the PAN-hosting option of "Join a personal network"
I have win mobile 2003 so BizzDev NetUse does not work
Any other way to do this?
It does work. I've tested it on both my iPAQ 2210 and PL720. It worked flawlessly.
Remember NOT to use network searching - it won't really work over BT (neither will with alternative programs - for example, Resco File Explorer). Enter the share name directly into NetUse.
when i input local name and remote path (in bizdew net use)and click ok following happens:
1. don't see network log on screen
2. On bizdew net use main screen a new mapping (aaa) DOES NOT appear
Thanks, the problem is that the ppc and all the other computers in my network see each other but when I clicked on the computer that has os sp2 it will prompt for a password for the guest account. In sp2 there is no way that I know to assign a password to Guest account. The same thing happen when I tried to access the same pc from my PPC. I just read the link and it explains BT. With the other computers I assigned a password to the guest account.
__________________
Advertise in Style
Free Advertising http://www.devenlink.com
Yes, I can even access the share folder on the pc that has sp2. The problem is that I can access the pc that has sp2 share files or folders. It keeps prompting for a password.
__________________
Advertise in Style
So where can we go with this? I am having the same problem with sp2 server. Netuse will not store my server name although I have got a PAN network connection connected to my ppc. I am using WM 2003 SE.
Ok, everything has worked perfectly as per the instructions but I can only make see the network locations if I am also connected to activesync as well as the PAN.
Is this necessary?
Thanks in advance.
PS is there any way to make a shortcut to my activesync and PAN connections? Too many clicks when using the broadcom stack although it is WAY better than the original ms stack supplied with 2003.
I run SE now and BT stack version 1.0.0 build 3900
Is this necessary?
When I tested this on both my SP2 (MS stack) and SP1 (Widcomm stack) desktops, both worked without a parallel AS connection. It should work without that.
You mean you would like to see the 'Network with 'desktop name'' icon at the My Shortcuts category on your, say, Today screen?
I use PHM tools 'Traylaunch' which is quite handy but you need to input the exact location of the program you wish to run (although I have never tried it with any arguments) eg. program files\repllog.exe for activesync. I also run SPB pocket plus which Im sure you are familiar with? You can configure today shortcuts with this prog too.
I guess Im stuck with running both activesync and the PAN simultaneously? Not a problem if I can have some shortcuts!
quote:2, on the next screen, click Add and choose the already-paired (please note that you need to initiate the pairing process from Windows) Windows desktop icon.
Ok, I'm having a few problems. These might have been explained before, but I read the whole thing and I cant figure it out. I've got sp2, and 2003 se. So first I pair my devices (this should be done with activesync, right?). Then, I opent he Bluetooth Network Manager in my Bluetooth Manager software. Now I can't get my computer to connect to my device. Except, I had it paired at one time, then I went to the other program and when I switced back, it wasnt added anymore. Please help, thanks.
Ok, I got the devices paired (sorry). Now, I have another question. Ok, I open BizzDev Net Use, and I type, aaa as the local name. Then, I type in my computer name, (which shouldnt be important but happens to be UNIVERSI-HCVGT8) followed by \a. Does the "\a" part need to be just any file on my computer? Does that folder need to be shared over my network? Thanks.
Please forgive an old dudder but I am somewhat lost -
I have a Bluetooth Network connection and I have BizzDev Net Use up and trying to run. I know the (lengthy) name of my PC but I cannot find a “share” – I cannot even find a \Network virtual folder.
Are the “share” names the same in each of the boxes and how do I find them? I have tried numerous combinations, all to no avail. Am I just old and thick?
Help would be much appreciated
I had the same problem (got it working by the way). To use a folder, you first must make it 'shared'. To do this, take any folder, and right click it, then got to "sharing and security". Here, click the box next to 'share this folder on the network'. Then, in BizzDev Net Use, do the name of your computer followed by the name of the folder which you 'shared over your network' (will look like...\\computer name\folder you shared. And it should work out fine. (I did mine with service pack two, and XP pro, so it might look a little different on your comp)
Unfortunately, however, it still refuses to work. I have spent several hours over the past two days trying all manner of combinations without any success.
I am using an iPAQ 5555: I have a Bluetooth Network connection enabled and connected: I have created a folder “C\localbtnet” in the PC and have enabled sharing, giving it the share name of “btnet”: I have put various names in the top box and have tried “\\computer name\btnet” and “\\computer name\localbtnet” (and other things) in the lower box: I am still met with a blank page when I press “OK”.
If I press “Browse” or “Options” I see a Domain name. However, my PC tells me that it is set up as a Workgroup. Is this the problem? If so, how do I change it? – when I go into System\Computer Name\Enter Domain it tells me that I can’t!
Well, that is what worked for me, so I dont know. You have wm 2003SE? If so, make sure your not just enabling network connection, but that you are using the Personal Network Manager under tools to host a network that you add your computer too, then trying the DizzDef Net Use. It looks like you're doing everything else correctly though.
hey thanks for the great guide!
i have only one problem...im using the sotware combination you mentioned in your post and i can stream mp3s with 192kps but it fails with 320kps, seam like there is not enought bandwidth....
im using and ipaq 2210 with bluetooh and a BT access point linked into my lan switch...i thought BT was 700 kps....so why is that i cant play 320 kbps mp3s? is the overhead so big?
thanks in advance :)
Yes, it is. As I have pointed out in some of my articles (don't really remember which), the practical speed of BT is no higher than 220-240 kbps.
I would have liked to connect via resco file explorer. For some unknown reason, it provided impossible.
My question is:
<I'm here>[}:)] ---...........................................\ My handheld is in the upper floor, but
[?][?][?][?][?][?].....\ my computer is in the lower floor. Is
(this is my roof/floor).\ there any kind of reapeater, or a mirror
......................../ or anything similar which can be used
......................./ to overcome this obstacle? (bluetooth
<my computer is here>[8] wlan is NOT an option here)
My question is:
To my knowledge, there'r eno Bluetooth repeaters, unlike with Wi-Fi.
BTW, what kind of BT stick do you have in your computer, and, what PDA model do you have? With a Class I BT stick and a Pocket PC having excellent BT range (for example, the Fujitsu-Siemens Pocket Loox 720), I was able to flawlessly communicate via Bluetooth with two (!)concrete walls between.
If you can't change your Pocket PC, you could still give a try to a Class I domgle if you only have a Class II one. It'll result in some additional metres of range - in general, with typical Pocket PC's, about 30-50%, according to my own range measurements.
Interesting thing this Fujitsu-Siemens Pocket Loox 720 is - it's, theoretically, BT Class II only; still, it has astonishinly good range. I'd say it has the same BT unit as the Loox 600, the only one Pocket PC ever released with Class I.
Great article. Thanks for this. Even though I already had Bizzdev Net Use working, this is great to show other users - and to my clients as well.
When I orignally had 'Net Use' working, I used the Buletooth connection method with no problems at all. Then when I tried just using my SD Wi-Fi card, 'Net Use' refused to work. I couldn't figure out why until I did some tinkering. Here is what I found that I hope helps other users as well:
There seems to be a flaw in Windows Firewall under XP SP2 (and probably previous Service Packs). With the Windows Firewall ON, the Bluetooth connection method worked fine. But trying via SD Wi-FI card, it failed - and exhibited the behavior that other users have reported .. with not showing the drive in 'Net Use' after attempted mapping.
What I found was that when you turn Windows Firewall OFF, then it seemed to work fine. So investigating further, I finally found that it seems Windows Firewall gets confused on it's 'EXCEPTION LIST' for the 'File and Printer Sharing' entry. It's default 'SCOPE' (allowed IP addresses) is set by default to allow 'My network (subnet) only'. The problem I believe lies in the fact that most ALL computers using a PDA have more than 1 network adapter (being 'Local Area Connection' and 'Bluetooth Network' .. and possibly others).
The solution here seems to be to change the 'SCOPE' to a custom list ... and put in your COMPUTER'S IP ADDRESS followed by /255.255.255.0. This would look like so:
192.168.1.4/255.255.255.0
You must do this for ALL 4 entries here:
TCP 139
TCP 445
UDP 137
UDP 138
To get to this dialog to change these entries, do the following:
START > CONTROL PANEL > SECURITY CENTER > WINDOWS FIREWALL (on bottom - not the link in the top of this window).
Under the 'Windows Firewall' settings, click the 'EXCEPTIONS' tab ... then scroll down and highlight the 'File and Printer Sharing' entry ... then click 'EDIT'. Click on the first entry 'TCP 139' and click 'Change Scope'. Click the 'Custom List' setting and enter your computer's LAN IP address followed by /255.255.255.0. Again, this would look like: 192.168.1.4/255.255.255.0
Click 'OK' after you've entered the Custom Scope - then highlight the next entry 'TCP 445' and click 'Change Scope' again. Again follow the same steps as above entering 'Custom List' and your IP address followed by /255.255.255.0 (192.168.1.4/255.255.255.0 or etc.).
Change the next two entries, UDP 137 and UDP 138, the exact same way as above. Once you have all 4 entries changed, they should all display 'Custom' under their Scope setting.
After you do this and apply all changes (by clicking 'OK' and then 'OK' again), Bizzdev Net Use should work with no problems.
I have a screenshot of this that I can post if someone can provide me with a place to host it.
Like I said, this caused me a lot of frustration - so I hope it helps you out.
One other thing to mention - this also seemed to solve my 'ActiveSync' problem via SD Wi-Fi. It seems to now work as well.
Good luck .. and please post if this has helped you.
I have got an Asus MyPal 632 with Windows mobile 5 - I can establish a pan with my PC (I have got an USB BT Stick from toshiba) Ping with vxUtil also works fine. But I can't acess my files or any folders. Resco 2005 or NetUse can't find my computer. My Computers name is "wolfi" So I entered "\\wolfi\BMP" - the folder BMP is on C and shared. What should I do?
Hi, Can someone post a valid BizzDev NetUse link? All links are death. Looking over the internet doesn't show any valid link.
I was wondering if this program worked over wifi. However, I would like to test it myself.
Thank you!
The best handheld is the one that perfectly matches your needs: no more, no less! (Ipaqs 3630, 3670, 3730, 3850, 1945; Zire 72s)
burnticej
As a last resort, email me [:D]
burnticej
Werner Ruotsalainen
Moderator
4, download BizzDev NetUse fromhttp://joe.pconsulting.com.au/joe/netuse.cab ; transfer it to your PDA and execute it there so that it is installed. Start it.
Werner Ruotsalainen
Moderator
Setting up PAN with the XP SP2 BT drivers
klokan057
Werner Ruotsalainen
Moderator
klokan057
cant install BizzDev NetUse
when i unzipp it i get 3 files with " unknown" icons
what should i do
Werner Ruotsalainen
Moderator
Don't unzip it. Transfer it straight to your PDA and execute it there (just click it) using, say, the built-in File Explorer.
klokan057
Werner Ruotsalainen
Moderator
Are you sure you used the correct form?
\\machine network name\share name
klokan057
i used
local name:
pda
remote path:
\\Abit\E\Pda share
(this folder is set as shared folder in bt manager on my pc)
Werner Ruotsalainen
Moderator
Try a simple, operating system-level sharing and not that of the BT manager. It's most probably the latter that is causing the problem on the PC.
klokan057
i allready had whole e disc on sharing
bubusee1
Advertise in Style
Werner Ruotsalainen
Moderator
Can you access the share from other desktop (PC) machines on the local network?
bubusee1
Advertise in Style
bubusee1
I mean that I can access all others pc share files from the pc that has sp2. But can not access sp2 share files from others.
Advertise in Style
roostaar
R
roostaar
I cannot initiate the PAN connection from my 2003SE ppc. I can only start the connection from my sp2 XP machine.
I go..
New/Join A PAN/Host/ (select my pc) then i get 'Service discovery was unsuccessful'.
Any ideas? I dont want to have to fork out another £100 on a wifi SD card![:(]
R
roostaar
Well, I dont know what has changed but I can now connect to shares on my server. I tried a different share and now i'm in! Report to follow...[:D]
Werner Ruotsalainen
Moderator
Glad to hear that [:)]
roostaar
Is this necessary?
Thanks in advance.
R
Werner Ruotsalainen
Moderator
roostaar
Thanks for your help with this topic.
Russ
roostaar
Russ
Jack Turner
How might I do this?
~(jckrenrut)~
Jack Turner
~(jckrenrut)~
Jack Turner
~(jckrenrut)~
docdic
Jack Turner
~(jckrenrut)~
docdic
Hi jckrenrut,
Thank you for your reply to my query.
Should I give up now?
Jack Turner
~(jckrenrut)~
docdic
Thanks -
No, I don't have the SE.
Does that make a difference?
docdic
sarkaz
Werner Ruotsalainen
Moderator
sarkaz
wow BT sucks for streaming :D
thanks again for the feedback
burnticej
That's a smart and precise explanation!.
My question is:
Juan M Alvarez
jm.freeownhost.com
WIZA100
Werner Ruotsalainen
Moderator
kmrussell
TCP 139
TCP 445
UDP 137
UDP 138
Kevin Russell
Computer Works
Fort Smith, Arkansas
Werner Ruotsalainen
Moderator
Thanks for your post, Kevin [:)]
wolfi.thomas
wolfi.thomas
My PC is running Win XP SP 1
burnticej
Thank you!
burnticej
WIZA100
burnticej
Hi, I found a working link:
http://www.pocketpcfreewares.com/en/index.php?soft=504
If it doesn't work, try my personal link:
http://www.4shared.com/file/30467778/12a602e9/Bizzdev_Net_Use.html?dirPwdVerified=e47711ea
burnticej
WIZA100
Guest
so long of these message!good great and nice.
