Infrared TV-B-Gone?
Hello all, I'm new to this forum and I need some help. I'm looking for some software which would work the way in which this product does here www.tvbgone.com/home.php.
Basically its a device which sends lots of television off codes until the television is turned off. Is there any software which would enable me to do the same thing on my ppc? I have read about being able to do it with an iPod so I'm sure it can be done, but has it been made yet for the pcc? or is there an application where I could create this?
All help muchly appreciated :)
I am also looking for such an application. If anyone knows of such a thing, please reply.
I don't know any of such apps; however, there're tons of IR remote applications for the Pocket PC. Some of them have really extensive built-in controllable device lists. Yuo quickly look up the TV set you want to switch on/off from the list (or, quickly download the necessary driver right from your PDA from, say, a Philips Pronto archive), and off you go [:)]
Please seehttp://smartphonemag.com/forum/topic.asp?TOPIC_ID=17874 on the available options, the comments on the size of the built-in & accessible, additional code libraries etc.
Syndicate content
