Thanks Menneisyys
you were very helpful
actually I am new on i-mate
so if you can give some advices or recomend more software
it will be a great assist
Thanks Menneisyys
thanks ones again
sam[:D]
Sure.
First, check out the Encyclopedia of Software & Accessories here at PPCMag. You would most likely prefer software that has been nominated for the 2005 Best Software Awards.
Also, you may want to check out the link collection on Windows Mobile Technology. There're tons of links to high-quality comparative reviews there.
kindly if I might ask another thing
I need the software to change my voice schem into a girl voice
so the call receive will thing that i am a girl !
can you help ?
hi; does realplayer work in smartphones? I have big collection of media in rm format that I like to listen to on my moto-q smartphone but i can not find the software. are you aware of any realplayer alternative for smartphones.?
Also note that mplayer is also SP-compatible but requires a LOT of CPU. See my blog for more info.
------------------------------------------------------------------- You really want to check out the Smartphone & Pocket PC Magazine Expert Blog athttp://www.smartphonemag.com/blogs/ - tons of unique reviews, roundups, tips, hacks!
Werner Ruotsalainen
Moderator
Note that RealOne Player[/url] can only play .rm files on the PPC, unlike on the desktop. That is, you may want to give a try to [url="http://tcpmp.corecodec.org/about"]TCPMP isntead, it's orders of magnitude better.
samblackhorse
Thanks Menneisyys
thanks ones again
sam[:D]
Werner Ruotsalainen
Moderator
Sure.
samblackhorse
can you help ?
faroukalbouti
you can send me an email : faroukalbouti@hotmail.com and I will send you an attachment of of realplayer program that you can install .
faroukalbouti
my email :faroukalbouti@hotmail.com
I will send an attachment file with this program.
zomer
ee1mm
Werner Ruotsalainen
Moderator
It does - with some hacking. See http://www.modaco.com/content/smartphone-software-applications/223297/howto-install-realplayer-onto-smartphone/
