------------------------------------------------------------------- You really want to check out the Pocket PC Magazine Expert Blog athttp://www.smartphonemag.com/blogs/ - tons of unique reviews, roundups, tips, hacks!
If it is gone, you can send me a message.
I think that after 30 days they remove the file.
Readme.txt
iPAQ 3950 Pocket PC 2003 Update and also Restore Back to Pocket PC 2002.
FOLLOW THIS INSTRUCTIONS:
Remove device from cradle and put in "Serial Mode." :To do this, press the POWER button, button 2, button 4 and the software reset button at the same time.
You must stop Activesync. :To do this, check your running processes and kill WCESCOMM.EXE.
Execute "romupdate" from the same directory as the "nb0" files is in.
f you have your cradle connected with the USB, use the drop-down box and change the COM port to \\\WCEUSBSH001. Do not change anything else on the screen and hit OK. (If you don't see this option then you probably didn't kill Activesync).
This should take you to a terminal screen. Hit <RETURN> a couple of times and you should see the USB prompt.
To update the ROM, type "lnb 2003.nb0" or "lnb 2002.nb0"
The upload should start and you should see asterisks and some sort of symbol.It will let you know when it is finished.
I was wondering if you could help me, as i have problems getting the update to start.
i get to the point in the readme where i should type "Inb 2003.nb0", but it says this command is invalid.
this is what i typed:
USB>Inb 2003.nb0
Invalid command : Inb
For a help screen, use command ? or h
You are very close, maybe this is missing, type password BOOTLOADER
I read at resco.net
# When the program starts press enter a couple of times until the prompt USB> will be shown
# Type: password BOOTLOADER You should see this.
Here some extra information:
Load MultiTTY. Select "\\.\WCEUSBH00? from the dropdown list (if you dont see this activesync is probably still active). you should now see a white screen. press enter to display the "USB>" prompt
type 'h' for a list of commands. NOTE: most of the commands are locked out and dont appear in this 'h' menu. to unlock them you need the device password. im not sure if this is the same for every device but mine was "CPQHAMMER" (to find your device password type "mb 7500 11", which displays the memory dump at location 7500h).
if the password was correct the device should return "PASS". now if you type 'h full' it will display the complete list of commands.
I am very lucky to see the ppc2003 rom for 3950 you offer
on the web.but it is very bad the megadownload do not allow
user in taiwan to download the file.
It will be very kind if you can inform me another place to download.
thanks
nick huang in Taiwan
quote:Originally posted by generosa
Who is needed this you can download it from here, I put it there to help someone else.
Readme.txt
thanks
Dear Huang,
You also try it with Emule, you can find the same one. Emule is like
Kazaa etc.
If you know an other site to share what is no problem in Taiwan, I will put it there.
Ps. I read at some site that you have to rename it to nk.nb0
Werner Ruotsalainen
Moderator
eBay. It has been recently removed from HP's pages (http://search.hp.com/query.html?charset=iso-8859-1&hpvc=sitewide&la=en&qs=&lk=1&rf=0&uf=1&nh=10&st=1&qt=HP+iPAQ+Pocket+PC+h3970+wm2003&ocoldqt=3970+wm2003&oc=100781 ).
TheNimda
I found it on eBay, but i am from Romania, we cannot pay with pay pal.
TheNimda
Anyone?
Please help a poor romanian.
TheNimda
Still looking for it!
Bruce Allgire
Moderator
This ebay auction, although prefers Pay-Pal, doesn't appear to require it: http://cgi.ebay.com/Pocket-PC-2003-upgrade-iPAQ-3970-3975-3950-3955_W0QQitemZ8825421112QQihZ005QQcategoryZ15004QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Perhaps you can contact the seller and inquire on other payment options.
Same with this onehttp://cgi.ebay.com/Pocket-PC-2003-upgrade-iPAQ-3970-3975-3950-3955-HOT_W0QQitemZ9744941005QQcategoryZ80346QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Especially this one from the UK -http://cgi.ebay.com/IPAQ-3950-3970-POCKET-PC-PDA-WINDOWS-2003-UPGRADE-CD_W0QQitemZ8832165988QQihZ005QQcategoryZ69927QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps.
And now, back to your regularly scheduled forum.
generosa
ipaq3950rom2002and2003.zip
http://www.megaupload.com/?d=TJ7DF8HG
Readme.txt
Made Bye Sahin / The Netherlands...............
2003 October....
jdcon
has anyone tried this? is it ok to work with?
generosa
Yes it works with a person I gave a few weeks ago.
You have to read the readme and know a little bit of computers.
\\\WCEUSBSH001 can also be \\\WCEUSBSH002 or \\\WCEUSBSH003 etc.
jdcon
Alright! thanks generosa!
Have you tried it out? Do you recommend updating to the 2003version?
olegz
USB>Inb 2003.nb0
thanks in advance for any help,
olegz
generosa
I have no experience with this, I only found this rom to share.
But maybe you can look here for some more information,
http://www.resco.net/forums/ShowPost.aspx?PostID=2804
I read at resco.net
cisa2560
dear generosa
thanks
jdcon
hey olegz!
Any luck installing the ROM?
generosa
Originally posted by cisa2560
dear generosa
thanks
Dear Huang,
Kazaa etc.
olegz
yea it works great, and jawbreaker is the most adictive game ever - its worth updating just for that!
im gonna try and put linux on it next [:D]
thanks for the update,
olegz
jollin
Hi
I think I can help you
welcome you to website:http://www.batteries-depot.com
You can find whatever you want.
If you have any quetions,PLS let us know.
Best wishes
Sincerely yours
The best you choose,and the best service we offer, welcome to our website
jollin
Dear:
You can look for what you want in this website:
http://www.batteries-depot.com/battery-brand.php/ipod_Battery
best wishes
Your sincerely
Jollin
xande
asd
