I have a 6510 with a password on it, but today I went to enter my password and there's no keyboard icon.
I can't get into my iPAQ. I'm looking for instructions on how to use the device keyboard. I can't tell if I'm using numbers, lower, or upper case letters since passwords are *****.
you can record conversation while making a call or receiving calls by opening program note and pressing the recorders red button. you may also need an sd card for extra memory.
Wallabie71
bump
Can anyone help me with this? I woudl appreciate any help possible...
GrandmaJean
Only God...
Who else can do what He's done?
Only God...
richardhula
Try using the virtual keyboard by tapping icon at bottom/middle of screen. This allows you to see exactly what you are typing.
If that doesn't solve problem try soft-reset button at bottom of device.
If that doesn't work try hard re-set:
Press Phone button (green) + Phone button (red) + Power button + Reset button (all at the same time and for a few seconds)
This will return unit to factory/new setting. It will wipe ALL programs & data you have added since new.
If that doesn't work ask God!
Regards - Richard
midenet
larry uk.
richardhula
Thanks Larry - I think your advice might be a little late for Wallabie71, but I appreciate it.
The Camera button on my hw6915 doubled as Record one, but got used to initiate voice command. This should give me back (virtual) Record button.
Regards - Richard
