i use contact manager software on my nokia 3230 to backup my contact in csv file and now i buy 02 atom and i want to transfer my contact in to my atom...using oulook?...but how???..
What happens when you try to directly import it into Outlook via File / Import and Export?
------------------------------------------------------------------- You really want to check out the Smartphone & Pocket PC Magazine Expert Blog athttp://www.smartphonemag.com/blogs/ - tons of unique reviews, roundups, tips, hacks!
If you hasn't right tool, i recommend a csv outlook converter to you. I used Outlook Converter to convert outlook to pdf file, and found more file formats supported by this program. I only know it can help you keep your important emails, newsletters, and messages organized in one file. Other features and how to use it, look this : www.qweas.com/download/converters/document_converters/abc_amber_outlook_converter.htm , where I downloaded it.
Maybe it is your need.
Good luck!
Jacky.
__________________
[img]http://www.qweas.com/images/logo/qweas-3.gif[/img]Software Search Engine - search software quickly, accurately and conveniently for PPC, Palm, Mobile, PSP, Windows, Mac... [url
Werner Ruotsalainen
Moderator
Cstrikedish
Good luck!
Jacky.
