E-125 questions
Hello, I recently found my E-125 and decided to charge it, and it works fine, other then having to switch the battery to main for 5 seconds to reset it, then back to lock for it to turn on again.
I purchased a 2gig compact flash card for $40, with a $10 mail in rebate that I'm going to send out, and I can't seem to get windows media player to use it as a playlist.
I have to open the CF card with file viewer, then copy the songs I want into the playlist folder, which is time consuming and not what I intended.
Does anyone know if there is a way to play all the songs from the CF card without having to move them?
Thanks, scars
use media player 7.1 for pocket PC, i run it on my sx45i and it accesses my 1g MMC card and works a treat, although i am curious if it can read larger that 1GB storage media?
Syndicate content
