Hello All,
I'm trying to make my SanDisk Connect Plus 128MB + Wi-Fi CompactFlash working on my Sig3, I tried many CAB files to make it work but most CAB won't install at all or when it install it didn't detect my CF Wifi card. Any recommendation? It is a Prism chipset, dont know what version of it.
http://www.sandisk.com/Retail/Default.aspx?CatID=1110
I tried to install those drivers, but none of them want run on the sig3. I didn't install the language pack (english) too, does it matter? I want to keep it in Japanese for a while (even if I don't understand).
Thanks!
DarkShadow
John Ottini
Moderator
Dark Shadow
I don't know if this would work, but you might want to have a look at DamnSoft's drivers for the SanDisk Connect Plus 128MB + Wi-Fi CompactFlash.
http://www.damnsoft.org/cgi-bin/ghostgui.cgi?nographics=;app=projects;section=sandisk
If it works let us know! Be safe and backup your HPC before trying any new software. [;)]
Regards
John
Handheld PC Forums Moderator
The Handheld PC Newsletter
http://hpcnec.com/cgi-bin/simpleforum.cgi?fid=03
Handheld PC Newsletter - -
http://hpcnec.com/cgi-bin/hpcnec.cgi?fid=03
Dark Shadow
John,
Thanks for the info, I try to install the CAB file, but I get an error in japanese (that I can't read). I guess it's telling me that the CAB file is not for WinCE.Net? Is there a way I can force to install the package? That problem happen all the times with many CAB file that I tried to install.
Regards,
DarkShadow
cmonex
hey. ever heard of wceloadext? :)
you need to install this first (in RAM and never move it!), it'll allow you to install cabs (when installing set it to no CPU and OS check). let me know if you can't find it.
also, i got these sandisk drivers that are claimed to be working (this is two cabs, you need only one but i haven't had a chance to try it yet, unless someone lends me a sandisk card):
http://izemize.fw.hu/sig3sandisk.zip
Dark Shadow
cmonex: Wow thanks you so much! I installed wceloadext and use your CAB file and it work great! Sig3 is really an amazing HPC I love it already!
