Uninstallation problems on WinCE
hi
i am getting remove problems error when i try to uninstall an application on boot up of my winCE module.
it says that some "\Window *.Unload" file is still in use. i have no idea how or why and where this file is being created because it is not visilbe.
Always
Did you try a soft reset?
Do you have any programs in your Windows Startup folder, that automatically run when you start your Handheld PC?
Regards
John
Handheld PC Forums Moderator
The Handheld PC Newsletter
http://hpcnec.com/cgi-bin/simpleforum.cgi?fid=03
__________________
Handheld PC Newsletter - -
http://hpcnec.com/cgi-bin/hpcnec.cgi?fid=03
If you use your desktop PC, you can use Windows Explorer while Activesynced and view all hidden files on the H/PC. the file is most likely in the windows\startup folder.
Bob
Microsoft MVP - Windows Mobile Devices
www.technobrains.com
Smartphone & Pocket PC Blog
PDA Games
PDA Applications
__________________
Bob
[url="www.technobrains.com"]www.technobrains.com[/url]
[url="http://www.pocketpcmag.com/blogs/index.php?blog=15"]Smartphone & Pocket PC Blog[/url]
[url="www.clickgamer.com/technobrains.htm"]PDA Games[/
Syndicate content
