Seeking Phenom LG installation software
I have a Phenom LG. The installation disk with the software enabling me to connect my Phenom with my PC is damaged. Can anyone therefore tell me how to download the necessary software to my PC; or can anyone simply send me the necessary software?
Thanks and much obliged.
James Drake
praguereporter@volny.cz
James
The software you need to connect your Phenom with my PC is Microsoft ActiveSync. You can download this software at
www.hpcfactor.com
Go to the Support and Tutorial Section, then select Activesync 3.x Support under the Common Topics list. Then scroll down to the bottom of the screen and download ActiveSync 3.8 to your desktop PC.
Install the software to your desktop PC, run ActiveSync and then connect your Phenom LG (using your serial cable) to you desktop PC to create a connection.
Regards
John
Handheld PC Forums Moderator
The Handheld PC Newsletter
http://hpcnec.com/cgi-bin/simpleforum.cgi?fid=03
__________________
Handheld PC Newsletter - -
http://hpcnec.com/cgi-bin/hpcnec.cgi?fid=03
Syndicate content
