My old Handspring Prism is dying and I need to replace it. I was strongly considering the Palm TX, but I have major reservations about the reliability of its hardware. I started to consider Pocket PCs, and was impressed by the reviews of the Dell Axim x51. I was crushed to learn, however, that Dell no longer sells them. Can anyone name a reputable vendor I can get one from? What about extended warranties? I sure hope someone can help me!
Dale Daniels
Moderator
I ordered one of mine from a reliable seller on ebay. The other I bought from a seller in the Buy and Sell forum at PocketPCThoughts.com. Both went without a hitch and I got exactly what I wanted. It also give you the ability to shop around. You might pose this question on the aximsite forum also.
Dale Daniels
"Expert Online"
Smartphone and Pocket PC Magazine Blogs
pcgerard
I was hoping to find a new X51. I think I may have found one on a site called gizmos2go:
http://www.gizmos2go.com/product.php?productid=8827&cat=1731&page=1
It can be had with a two-year replacement warranty for an additional $100. I don't know much about them. How can I check them out? I'm a little leery of vendors that don't have a phone number.
I'd really appreciate your help on this.
Thanks!
exscentric
If you can find an address, go to BBB.com and find the branch near the gizmo business and most have a way to check businesses out online.
