Gamer for PPC/Smartphone
Windows mobile game modify for PPC/Smartphone 2003/200SE/WM5/WM6
Game inner quickly search, just two times search to find and modify the game, "Drop" key start game/back to game/back to Gamer.
Order/Download/Try www.handango.com/PlatformProductDetail.jsp?productId=211674
Tips:
Continue the last game to change the same parameter, and the result is same (no change), just "Write at first result" does not need the search action.
The first time search's parameter if just the number 0 or 1 or 2, or second time just search 0, is wasting time(no efficiency).
Change Step:
1. Start Gamer.
2. Press "Drop" in game back to Gamer.
3. Input searching number equal new value and "Start Search".
4. Play game wait the number changed, repeat step 2-3-4 until find one result(normally 2 times find the result, playing the different sound when value changed).
Press "Drop" key back to the game, or click the result label which bellow the search box, will back to the game too.
Start Gamer want to play the last game and the game not started, just press "Drop" key to start the game, or Click the result label to start the game.
Searching number format is "Data=New[,New...]", the "Data" or "New" can be normal number, hex number(0x prefix), float(f end), 64 bit long(L end), string(inner ""); "New" can be maximize 32 numbers, means change the value in continue position more values.
When start the game new stage, you can use "Write at first result" to check the adrress, not changed the value means address invalid, needed "Restart Search"; in same stage you can use "Write at first result" to change the value; if the same parameter always find the same address, next time just "Write at first result", does not need search again.
Modify example: Change "Pocket Heroes"'s experience to 10000000.
1. Start Gamer.
2. Start "Pocket Heroes" and start new stage, check the heroes's experience(like 625), press "Dorp" back to Gamer.
3. Input number 625=10000000, and click "Start Search" or "Restart Search"
4. Play the game, when experience changed(like 1625), press "Drop" back to Gamer.
5. Input new number 1625=10000000, and click "Start Search", you will get the different sound notify, and the experience changed to 1000000.
In step 5 if your input is 1625=10000000,10000 you can find heroes's mana change to 10000, so mana followed by experience.
"Pocket Heroes" changeable number like:
Resource 10000=1000000,10000,10000,10000,10000,10000,10000
Experience 375=1000000,10000(Second one is mana)
Attack/Defense 5=100,100,100,100(Attack,Defense,Spell,Knowledge)
Travel Points 66=100000
Split Army 4=3000(Split one group army to two group army, make the number changed to find the army numbers)
"AZGard defence":
100=2100000000
FAQ:
1. How to switch window in Smartphone WM6?
If the "Drop" key does not work, you can use # key to switch the windows.
2. Why sometime switch to game, the screen freeze?
May be the game does not get the notify, but you can switch("Drop" key) more times to active the focus and screen.
3. If th result always more than one result(like "Enslave"), how to change the number?
Just "Write at first result",if the results not changed.
Anyone tried this app? Does it works as it should on WM6?
Best regards,
Henrik
___________________
Coola barnkläder och babykläder från xitrus
Best regards,
Henrik
___________________
I passed the test on WM6, some times need more times "Drop" key press to switch the interface.
Syndicate content
in array stripos
