looking for bluetooth sound transmitting device
alright so i have a windows mobile x50 dell axim, and i downloaded a program called stompboxes for it. However since i get a whole crapload of feedbac from it, i wanted to just plug my guitar directly into it. However, there's no input for it. Is there any blue tooth device i can use that i can plug a guitar or microphone into it and it transfers it to my device? or is there another way? Im not really caring about wires or not, i mean wireless is nice though. but so is cheaper.
ok people seriously it doesn't even have to be bluetooth, or wireless, i just want a thing i can use that will make the pocket pc use that device as default microphone...really.
[quote=mudrock1000]ok people seriously it doesn't even have to be bluetooth, or wireless, i just want a thing i can use that will make the pocket pc use that device as default microphone...really.[/quote]
Is it an x50 or an x50v? If the latter, you're saved - the x50v does have a sound input in its headphone connector. If the former, you can only go the low-quality BT headset or the very expensive CF-based solution, PDAudio. For all of these, check out my mono BT article and the Audio Recording Bible on my blog.
Syndicate content
