I have a Motorola Q9h smartphone with Windows Mobile 6 and so does my husband. I sync the smartphones with Outlook on my PC. Syncs seem to go fine. However, I cannot access the task list on the smartphone. If I launch tasks, I get an error message "no memory available".
I have tried cleaning the memory, doing a soft reset, and tentatively exploring system files with Resco Explorer. I can't figure out how to fix this error message so that I can use tasks.
Tasks launches fine on my husband's smartphone, and it has been synced to the same Outlook.
LAR
Werner Ruotsalainen
Moderator
1. How many task records do you have?
2. what additional apps are you running / have you installed? Can you post a screenshot of the installed apps list?
You really want to check out the Smartphone & Pocket PC Magazine Expert Blog athttp://www.pocketpcmag.com/blogs/ - tons of unique reviews, roundups, tips, hacks!
meslierlp
Moderator
Did you install an application recently that might have caused this? If I were you, I would backup my data and perform a hard reset.
Linley Meslier
MS MVP - Mobile Devices
Http://PocketPCMauritius.blogspot.com
Devices: Eten M500 + WM5 & HTC S620
