Can one convert 'm4p' music fille format?
I downloaded music from ITune.
- Unfortunately, the
muusic format is
unplayable by WMP
[ppc or pc]
- Can one convert m4p or
mp4 to wma or mp3 for
WMP on PPC?
Thanks!
Happy computing!
peterskis3@netzero.com
__________________
Happy computing!
From what I understand, with third party utilities, the answer is no. But I beleive it's possible within the ITunes player for Windows to convert the file to MP3. Not sure though as I've never used it.
Administrator - PDA Core
PPX Demo - www.ppx3k.com/index.php?op=description;id=571
Sites - www.pdacore.com
__________________
SUBJECT: How to convert M4P files to MP3 and WMA, using (a) ITune, (b) a CD -burner and (c) WMP v9
Thanks, VRam for pointing out possible features within ITune, CD
Here’s what I found out that works, using the ITune and WMP v9 to convert M4P files to MP3 (and/or WMA). No other 3rd party program was used.
(1) Yes, Itune itself has a feature for converting downloaded M4P files to MP3. When I tried that, however, I got a
message, “these M4P files are protected property and cannot be converted to MP3.
(2) Luckily ITune also has another feature for burning downloaded files directly to CD-R as “Audio CD”, in the .cda
format.
(3) So, I used this CD-burning feature to burn a music CD with all purchased music files.
(4) Then, I opened up Windows Media Player v.9, and used the feature ,“copy files from CD” to convert the .cda files
from CD to WMA or MP3 files to the Library.
Peter
Wed, 06.23.04
Happy computing!
__________________
Happy computing!
As a logical exercise, you could have just chosen, in WMP, "Copy to Mobile Device" to replace part of number 4.
__________________
Thaks for your posting. I just tested it but all of my files were exported to CD as w4p files. Do you need to change a preference somewhere?
format.
Peter
Wed, 06.23.04
Happy computing!
To convert m4p music to mp3 wav or wma, You can convert m4p to m4a first, and then convert m4a to mp3 or wma. Please visit www.topvideopro.com/mp4-m4a-converter/convert-m4p-mp3-converter.htm for more infomation.
How to listen your protected music on your iPod or other digital devices without supporting protected content playback and particular DRM technology? May be this issue have disturbed all of you for a long time. Don't worry about it now,M4P Converter shall help you to solve this troublesome problem. let's begin to know more details about www.m4pconverter.biz
Syndicate content
